Improvements to Onshape - November 9th, 2018
bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373
edited November 2018 in New in Onshape
Another 3 weeks, another amazing update from Onshape including some highly requested features! Customers who have submitted tickets that are addressed by improvements in this release will be notified in the coming days. If you have improvement requests, please submit your ideas here. Let us know what you think.
CAD IMPROVEMENTS
REPLACE PARTS IN AN ASSEMBLY
You can now replace parts in an assembly with any other part, even from other documents or standard content.
https://onshape.wistia.com/medias/jp82co0xsk
DRAWING CALLOUTS ALIGNMENT
Drawing callouts can be aligned vertically and horizontally with the first selected callout in a selection from the context menu.
https://onshape.wistia.com/medias/aunds15h2e
DUAL UNITS PANEL IMPROVEMENTS
In the dimensions panel, there are improved options for control over dual units. By default, a dimension will follow what's set in the drawings properties panel or you can select for the chosen dimensions to either show single or dual units independent of the drawing properties.
https://onshape.wistia.com/medias/9avgsuwf5y
IMPROVED INSERT VIEW DIALOG WITH SCALE OPTION
New with this update is a view scale option added to the insert view dialog. You can set your drawing view scale upon insertion instead of needing to perform a secondary action.
https://onshape.wistia.com/medias/ypf369uo9x
UPDATE DRAWINGS DURING VERSION CREATION
When creating a version you will now be notified if any drawings are out of date along with the ability to update those drawings through the version creation dialog.
https://onshape.wistia.com/medias/tvsend44in
BEND NOTES AND HOLE CALLOUTS IN PROPERTIES PANEL
Bend notes and hole callouts are added to the annotations tab of the drawing properties panel. Here you can modify the font, text height, and color of the bend notes and hole callouts.
https://onshape.wistia.com/medias/1rj4me5gmk
ENTERPRISE FEATURES
SPECIFY USERS FOR RELEASE CREATION
In Enterprise, you can now specify who is allowed to create a release candidate as a global permission to go along with the existing ability to control who can approve releases. Remember, global permissions are controlled by an enterprise administrator.
https://onshape.wistia.com/medias/ljlup7xbee
REPORTING PERFORMANCE IMPROVEMENTS
This update includes performance improvements to enterprise analytics reports. Initial report opening time is now faster as well as navigating between different reports within a session.
https://onshape.wistia.com/medias/3ps9pnfaiw
Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the Onshape changelog.
Twitter: @bradleysauln
«1
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    Hells yea, replace parts! Can't wait to get home and put that to the test
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    Awesome and a great way to start the weekend! Don't forget to check the Changelog. There are some goodies hidden in there. Thank you to everyone at Onshape for finally implementing Replace Part in an Assembly. I hope this is leading up to some assembly configurations in our future  ;)
    Just in time for my rubiks experiment... I'm figuring 250 + mates and a few relations for those 27 parts :D
  • Andrew_Enslow_3DSAndrew_Enslow_3DS Member Posts: 40 ✭✭✭
    Thanks for Replace Part! Really Excited about that!
  • romeograhamromeograham Member, csevp Posts: 714 PRO
    Replace Part is awesome! Thanks Onshape!
    Hmmm...only works for Parts for now (can't replace Assemblies yet).
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    Replace Part in assembly is a great improvement, this will come in very handy. Also, the scale view before inserting is a nice touch to drawings, I nearly always have to change after inserting but this will make it much easy to get it right first go.
  • gerhard_swanepoelgerhard_swanepoel Member Posts: 29 PRO
    Great updates!
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,059 ✭✭✭✭✭
    Why do modified dates more than 2-3 weeks ago only show as dates and not the time?
    Was this changed in this update? :(
  • Why do modified dates more than 2-3 weeks ago only show as dates and not the time?
    it only goes back one week! for the same day last week it only shows the date, not the time. I was using this for checking time spent on a project.
  • Hans_Ole_LeirvikHans_Ole_Leirvik Member Posts: 82 PRO
    Great improvements  :)
  • don_williams909don_williams909 Member Posts: 146 PRO
    Excellent stuff...!
    I immediately tested the Replace Parts feature and it works seamlessly, from what I can tell.
    For me, it's basic functionality that i figured you folks would get to eventually.
    Nice work !
    @john_mcclary - John, thank you as always. The guys/gals work very hard on this stuff and we all read these comments. As you know by now, we release an initial take on something and then collect feedback from the users and then have a second or third round. It's not that we forget to do something, or aren't smart enough to know that we should do something - it's a process (this is more for others than for you :)). So you let us off lightly, you dont want the option to have the balloons equally spaced? ;)
    Philip Thomas - Onshape
    Sorry if I sounded like I was saying you forgot or whatever, I know better than that :) (I just over explain stuff, a.k.a. Ramble)
    Yea equally spaced is good once in a while, but I do tend to have that option Off more often with magnetic lines in SW. The parts are not usually equally spaced and I think it looks nicer when all the lines are shooting off at the same angle, rather than the balloons being equal.
    Replace part looks great, thanks for the hard work. Owen S.
    @john_mcclary - I wasn't busting your coco's - you're absolutely right and we need that feedback! :)
    Good feedback on the equally spaced perhaps being less important than other things.
    We have some major projects in the pipeline and we are all very excited to give them to our users between now and (best guess) the end of January - hold onto your hats! :)
    Holding :
    @john_mcclary MAGBA has a nice ring to it.
    @philip_thomas   I'd vote for parrel leaders rather than equally spaced balloons.
    Great stuff, can't wait to test replace part. Setting scale 'on the fly' is confirmed click saver.
    Thanks!!
    It looks like Replace doesn't work for surfaces yet.
    What about parts to sub-assemblies or vise visa?
    Great improvements
    Replace part looks promising... It may be a good option to allow select a part in the assembly as replacement part
    We are happy to see so many improvements in drawings.
    Un saludo,
  • Song_YikunSong_Yikun Member Posts: 39 PRO
    Replace part !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Great improvements
    I just tried a replacement of a weldment tube very similar to the picture here of Eduardo's, unfortunately, in this case, it replicates the part at the original global zero position, it would be nice if we could have an option to replace a part centroid to centroid of the body.
    What about selecting mate connector of existing part and then selecting mate connector of new part and insert there. Similar to 'move by mate connector' in part studio.
    Am I the only one who is constantly struggling with inserting parts into assembly? Search is useless since it shows all the parts in the world (public) and there's no folder structure in insert dialog. Only labels, which are very handy but not prompted to add when creating new document.
    I would like to see very soon in insert dialog:
    - Search only My documents
    - Folder structure
    and
    - Ability to add labels to new doc in naming dialog (before opening doc)
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,887
    - Folder structure
    and
    Hi @3dcad - insert dialog does have search in "created by me"?
    - see folders - yes please
    - add labels when inside a doc - yes please
    Can you create IRs?
    Thanks,
    Neil.
    Duh, never clicked on My Onshape :flushed:  - there was folder structure and search is fine too when used from there.
    I will write an IR to default there and require extra click to search public stuff, for labels I already did.
  • Bill_MartinBill_Martin Member Posts: 26 ✭✭
    Is there an existing improvement request for "replacing a part referenced in a drawing view"?  I'm embarrassed to ask because I might already have voted on it and can't remember like so many other things these days!
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 556
    @Bill_Martin I created a ticket for you.  This is a separate improvement for drawings and something in the plans to deliver on.
