Assembly Mates
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Can anyone give some advice please. I have modelled a ball bearing in part studio and the mated it together as a sub assembly.Every thing works fine, when outer ring is fixed, inner ring, balls & cage revolve fine. When moved about the screen all parts remain together when outer ring is unfixed
However after inserting into the main assembly, when trying to mate to the main assembly the outer ring explodes from the balls, cage & inner ring. Depending on which mate I try to use in some cases the whole bearing explodes. Obviously I am going wrong some where, It will be very much appreciated if anyone can help so that I can move on.
Best regards Brian.
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    Marvellous John, will sleep better tonight, Got visitors at the moment but can't wait to try. will post how I get on ASAP
    Cant thank you enough. Brian
    Thanks again John, Just followed your detailed example and everything is working fine.
    Till next time, All the best. Brian.
