Improvements to Onshape - November 9th, 2018
Another 3 weeks, another amazing update from Onshape including some highly requested features! Customers who have submitted tickets that are addressed by improvements in this release will be notified in the coming days. If you have improvement requests, please submit your ideas here. Let us know what you think.
CAD IMPROVEMENTS
REPLACE PARTS IN AN ASSEMBLY
You can now replace parts in an assembly with any other part, even from other documents or standard content.
DRAWING CALLOUTS ALIGNMENT
Drawing callouts can be aligned vertically and horizontally with the first selected callout in a selection from the context menu.
DUAL UNITS PANEL IMPROVEMENTS
In the dimensions panel, there are improved options for control over dual units. By default, a dimension will follow what's set in the drawings properties panel or you can select for the chosen dimensions to either show single or dual units independent of the drawing properties.
IMPROVED INSERT VIEW DIALOG WITH SCALE OPTION
New with this update is a view scale option added to the insert view dialog. You can set your drawing view scale upon insertion instead of needing to perform a secondary action.
UPDATE DRAWINGS DURING VERSION CREATION
When creating a version you will now be notified if any drawings are out of date along with the ability to update those drawings through the version creation dialog.
BEND NOTES AND HOLE CALLOUTS IN PROPERTIES PANEL
Bend notes and hole callouts are added to the annotations tab of the drawing properties panel. Here you can modify the font, text height, and color of the bend notes and hole callouts.
ENTERPRISE FEATURES
SPECIFY USERS FOR RELEASE CREATION
In Enterprise, you can now specify who is allowed to create a release candidate as a global permission to go along with the existing ability to control who can approve releases. Remember, global permissions are controlled by an enterprise administrator.
REPORTING PERFORMANCE IMPROVEMENTS
This update includes performance improvements to enterprise analytics reports. Initial report opening time is now faster as well as navigating between different reports within a session.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the Onshape changelog.
Hmmm...only works for Parts for now (can't replace Assemblies yet).
Was this changed in this update?
In solidworks this separate command is just a prompt when you edit an existing mate's broken or missing selection, which is better, because it doesn't require the user to even realize that is possible. It's always a pleasant surprise (Best feature to come out of solidworks since the close button).
It is awesome we can line up balloons now without drawing a line then snapping to it, but it would be nice to be able to align parallel to a selected object, or at ISO angles. To follow along a conveyor line for example.
I immediately tested the Replace Parts feature and it works seamlessly, from what I can tell.
For me, it's basic functionality that i figured you folks would get to eventually.
Nice work !
Yea equally spaced is good once in a while, but I do tend to have that option Off more often with magnetic lines in SW. The parts are not usually equally spaced and I think it looks nicer when all the lines are shooting off at the same angle, rather than the balloons being equal.
Good feedback on the equally spaced perhaps being less important than other things.
We have some major projects in the pipeline and we are all very excited to give them to our users between now and (best guess) the end of January - hold onto your hats!
@philip_thomas I'd vote for parrel leaders rather than equally spaced balloons.
Replace part looks promising... It may be a good option to allow select a part in the assembly as replacement part
We are happy to see so many improvements in drawings.
I would like to see very soon in insert dialog:
- Search only My documents
- Folder structure
and
- Ability to add labels to new doc in naming dialog (before opening doc)
- see folders - yes please
- add labels when inside a doc - yes please
Can you create IRs?
Thanks,
Neil.
I will write an IR to default there and require extra click to search public stuff, for labels I already did.
