This is the most frustrating CAD program I have used so far
Kley_Gilbuena
Member Posts: 1 PRO
Hi-for one or more reasons I need to import .stl files into OnShape, make them parts and then output them to another piece of software. I can not only NOT find out in any research how to properly produce a part from a mesh nor can I actually export the mesh as a file. Each time I try to calculate the bounds for a mesh I get a bounding box that get imported as a box. This is not useful at all. I realize there are other ways to get around this using other software but for a class I am supposed to be using OnShape. Can someone please help me understand how to consider meshes/.stl files in OnShape or point me to learning resource where there is a tutorial? Thank you
https://cad.onshape.com/documents/16e6db3562f6d010706c7332/w/205444fb7c0078092d352c1f/e/861734c413a4173d6c1773fc
any advice @NeilCooke ?
The Steam Iron is an example of how meshes are intended to be used in Onshape - as a reference for building exact BRep geometry. Meshes cannot be converted to solid (yet), so they cannot be turned into a real part.
