Problem with simple Lofts
milos_necakov
Member Posts: 3 ✭
I am new to Onshape, but I have used loft successfully few times until now.
I discovered that without reasons clear to me a simple loft between two circles on parallel planes will twist.
For example, if i draw circle on top plane and two circles to new offset parallel plane, and try to apply loft between circles, it should give me straight simple lofts, right?
It does, but only on some, and not always. Is it a bug?
Here is my test on three parallel planes trying to apply simple loft between circles. As you can see some of them get narrow or even cross between two circles.
Can anyone tell me why please?
Thanks in advance!!
https://cad.onshape.com/documents/c6636d318623ab69f895d9d1/w/4b061956849c1e085282c3fe/e/a3486ab41499c41e7f5cbbdc
Thanks in advance!!
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
@milos_necakov This is a simple fix that is part of the loft feature. Remember there is a lot going on when a loft is made even to determine how 2 circles should join through 3D space. If this ever happens, this is where you will use the match vertices options. A few seconds to add a construction line through the circles causing you trouble and you are good to go!
Take a look at my copy of your document
https://cad.onshape.com/documents/affe071b3542456bd62d9784/w/a94f8b77f79091744383340a/e/efeb0ade5ffa7a4fd106d7ad
6
Twitter: @bradleysauln
Cheers
