Another design (performance) contest
emagdalenaC2i
Member, Developers, Channel partner Posts: 860 ✭✭✭✭✭
in General
This time instead of the usual contest to design this part with the least number of features, the goal is to achieve the shortest regeneration time in the Part Studio.
Have fun and a nice weekend
Here is the PDF file https://cad.onshape.com/documents/4c8a1306d9e39fb784cd9e2c/w/b8baf46b46ffe8f24f6ed5c4/e/d6227816c1d450f5c0ef345c
Un saludo,
1
Is featurescript allowed
https://cad.onshape.com/documents/42d651c1db661ed81bc335cd
PS: Don't look at the dimensions on the sketch
You beat me in the first attempt
I knew thicken is a bit faster than extrude but I did not remember to use it in this example
In a few days we will publish an article on our blog with some tips and tricks.
Thanks
...If you create a new Part Studio with a derived feature of your part ;-)
Of course you "should handle carefully the derived features": Link it to a version, avoid circular references, and something that @lougallo call "the daisy chaining of derived features" XD
@mbartlett21 you looooser
Maybe it regenerated on a faster server
In that case it should be faster for me too!
