PDFs, Part Numbers, and Assemblies
tim_hess427
Member Posts: 648 ✭✭✭✭
This may be a little bit off-the-wall and half-baked, but wanted to throw this for some feedback - I'd like to be able to add non-3D parts to assemblies. Is this a bad idea? Why or why not?
I think I'd like to be able to add PDFs and other file types to assemblies. There at times where I have things, such as labels, that do not require a 3D part. Currently, I can upload a PDF (or other graphics file), assign a part number, and even use release management to manage revisions and sharing. All of this is great, except there is no way to get that part number onto the BOM with everything else. This leaves me with the options of trying to manage two different BOMs (the Onshape BOM plus an additional external BOM) or just ignore the Onshape BOM outside of call-outs on drawings.
Is there a workaround or some functionality I'm missing? Should this be a feature request? I'd love to hear other's thoughts.
But It would be nice to be able to add "Dumb Rows" to the BOM without a 3D reference part.
Did you actually want the PDF to appear in the model? or are you just trying to get it on the BOM?
If I recall, OpenBOM will let you add extra rows of parts that are not on the model.
I hadn't thought about making a dummy part to get the part number on the BOM. I'll play around with that. Also, I don't actually want a PDF in my assembly, but I could see a case where the PDF or graphics file defines an item (such as a label) and it could be useful to associate it with the assembly so that it's captured on the BOM.
I'm more interested in trying to get all the appropriate information into the right BOM.
OpenBOM allows you to add non-model parts to BOM created from Onshape and keep it in sync with Onshape.
I just wrote the article that explains how to do it in OpenBOM
https://medium.com/@openbom/openbom-non-model-parts-in-bom-for-onshape-and-other-cad-systems-640d800111a2
OpenBOM for Onshape is FREE again
https://medium.com/@openbom/new-openbom-subscription-model-brings-back-free-openbom-application-for-onshape-2e226ede27d9
We are working on improvements for multiple document use cases and Release management integration.
