Assembly drawing questions
in Drawings
I have been working my way through various tutorials (complete beginner) and using the attached drawing as an exercise. So far so good, but I have a question regarding the drawing produced from an assembly. To my mind the lines between the assembly elements are not required - is there a way to eliminate these so that the part is "seamless"?
I also need to mark up on the drawing areas which will have a coating applied - any suggestions or advice as to how this might be done, and at which stage, would be appreciated. I can do it with a coloured marker on a hard copy but I suspect there may be a way to do it as part of the process.
Thanks in advance,
Peter
https://cad.onshape.com/documents/51d01ef742e61646e02f422a/w/7bb485bcc00d5916787cabaf/e/96c6ac58f851245e332a1d72
Thanks in advance,
Peter
you can only have one color per part right now. so this may be an decnt method for now.
otherwise you can sketch a line in the drawing and call it out that way.
Peter
