Welds - custom feature script
urszula_wachulska
                    Member Posts: 21 PRO
            Hello,
nDraft team has developed a prototype of a tool which creates models of weld connections in welded constructions. For now it’s just a sample of what we plan it to be.
On our blog you can read more about our purposes and advantages of modeling weld connections: https://goo.gl/y5ksvY
We are going to expand this feature script with:
other types of weld connections,
weld connections according to other standards,
geometric data of weld connections and limitation of use included in the csv file
We would like to know the opinions of other constructors and technologists. Any comments about how this feature script works or ideas which would be worth to implement will be appreciated.
If you are enthusiastic about Onshape feature scripts - we are open to cooperation on writing the other functions.
Script can be found here: https://cad.onshape.com/documents/4d1e11aaa3728e4140753327/v/6fce43854572504287864f1c/e/24552dcb22a189d765aa6993
We could take the nDraft's code as starting point and create some branches for the main development lines and use PR (Pull request) so anyone can collaborate.
@bill_daniels actually Onshape don't support textures but it will be easy to set a defined appearance, and even a user customized appearance
I have created a weld feature that will take faces as input, and it can handle weld gaps and non-90-degree angles
https://cad.onshape.com/documents/7c7042b84e1ae5b391af796f
Personally I would like to create an open repository in GitHub for a project like this, which may have many options and many people interested in contributing.
If it is not with this project it can be with any other
We can't merge very well for Feature Studios
But the only way I can figure out creating a kind of PR (Pull request) in an Onshape document, approve it and merge is... Using the Release management ;-)
Unfortunately, although all possible collaborators could have Onshape Professional accounts, we belong to different companies...
So, maybe Onshape could add the Release management system to the Standard / Free accounts
Here is mine in a repository:
https://github.com/mbartlett21/weld-featurescript
hello everyone,
we would like to thank you for your interest. All comments are appreciated.
Lately we have been quite busy with finishing an important project as well as preparing quite demanding but rewarding bid offer. All of this caused we had to sideline our weld featurescript for awhile.
Now this crazy deadlines time has calmed down a little bit and we are back on track with welds feature. We collect some more data on weld connections, to ensure appropriate substantive level. On friday we will respond more accurately on your comments.
As far as I know, custom features scripts in Onshape work in part studios only. But weld connections can be inserted to assembly as every other part.
For calculations we usually prepare different models of our constructions. We do this by creating another part studio, then we derive parts from original one and merge them using "boolean" command.
Will that work for you? If not, please let me know more specifically what do you need.
We used edges with the thought about v-butt welds - to show which edge should be machined to create necessary bevel.
Our welds custom feature scripts was just a sample - we wanted to show you what we want to do, so it has many limitations.
As to collaboration:
If it is possible we would like if Onshape team could create for us a development project / document which we could admin. This way we could create a team of collaborators from different companies and keep everything under control. After finishing some stage we could create a public version.
If this is not possible, we can work in public project or go for this GitHub. But in my opinion public project could create some mess. And about GitHub I must say, that I am not familiar with it. I am just a mechanical engineer not a programmer. Could you tell me something more on how it works and how you see working there?
When programming in gitHub do we get prompts from Onshape? (not sure if i said it properly, what I mean is: when I start typing a command in feature script studio possible commands appear and I find it really helpful)
You don't need Onshape's assistance to do that. You can create a team in Onshape and share the Welds document with all programmers who request permission to collaborate.
GitHub is not a programming environment or IDE. GitHub is a web-based hosting service for version control using Git. It is mostly used for computer code.
So you would continue programming inside a FeatureStudio in Onshape, in the same way as the other programmers who collaborate in this project. Each programmer can work on their own document in Onshape.
When a programmer makes an improvement or modification in the code, they can upload the code to GitHub and create a PR (pull request). This PR system is more or less like the Release workflow in Onshape. Therefore, you can approve (merge) that PR and create a new version in the Onshape document whenever you want with all the added improvements.
You can take a look at @mbartlett21 repository
I have created a fork of that repository (it is like a copy) https://github.com/Change2improve/weld-featurescript
and have created a new branch (more or less like Onshape's branches) https://github.com/Change2improve/weld-featurescript/tree/Spanish-translation
then I have change the code and create a new PR (pull request) https://github.com/mbartlett21/weld-featurescript/pulls
In that PR you can see the proposed changes or improvements https://github.com/mbartlett21/weld-featurescript/pull/1/files
That is more or less like when you compare two versions or branches in Onshape, but showing the differences in the code instead of the differences in the design.
@mbartlett21 Please, don't merge that stupid PR ;-)
So, bottom line: Onshape is a great application for design and Feature Studios are a great IDE to create custom FeatureScripts features. But Onshape don't provide a release management system that can handle changes in the code of a Feature Studio.
I have just updated the repository from Onshape
PS: You now have some pull requests on your branches
@urszula_wachulska
Public documents only mean that everyone can view it and not edit (unless it is explicitly shared with them)
When programming in GitHub, we will not get popups like Onshape.
You can edit it in Onshape, then copy it into GitHub, where it will work out all the insertions and deletions.
It also will then merge better
Here you can see all the code history https://github.com/mbartlett21/weld-featurescript/commits/master
@urszula_wachulska you can create one or more issues in the repository https://github.com/mbartlett21/weld-featurescript/issues
I have already created an Issue to discuss what improvements could be included in a first version. https://github.com/mbartlett21/weld-featurescript/issues/2
I have just added you as collaborator
@urszula_wachulska
Do you have a github account?
