Properties
Josiah_Harthcock
Member Posts: 57 PRO
Viewing properties of a part directly from any of the levels of the assembly without opening the individual part would be awesome!
3
You can edit it in the BOM
@lougallo on the cross highlighting, it works well from the BOM to show all locations but I also really what it to select an item in the workspace and have it show the row on the BOM, this would be ideal for adding properties from blank parts
@mbartlett21, this trailer was done with your AusBeams FS.
Some of our BOM's take over 30 seconds to open however I shouldn't complain
Absolutely agree on highlighting parts in the assembly and having them highlight in the Bom. would be a big plus!
I'd be happy to help you with OpenBOM if you decide to explore more. OpenBOM has an option to create a template to define what columns are coming from Onshape to BOM.
OpenBOM for Onshape is FREE again
https://medium.com/@openbom/new-openbom-subscription-model-brings-back-free-openbom-application-for-onshape-2e226ede27d9
We are working on improvements for multiple document use cases and Release management integration.
