Mate connectors in Part Studio stay behind when I transform their owner part
chris_8
OS Professional Posts: 102 PRO
Am I missing a way to bind the part to the mate connector?
thanks,
Chris
Example:
https://cad.onshape.com/documents/6b714e18e39e7a82c583e9db/w/1b919740fcf6075f60128924/e/3e3023a32957b2f261920b77
thanks,
Chris
Example:
Optionsbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,137 PROMate connectors don't bind to the part in the part studio but if you select the mate connector in the move feature it will move as well.6
Optionsbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,137 PRONo, it is not possible to move a sketch with the move feature.
The only way to move a sketch would be by rolling before the sketch feature in the tree and move the sketch plane before the creation of the sketch. Off course this will also depend on how the sketch constraints are referenced to the origin or other geometry.5 -
Optionsbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,137 PROchris_8 said:Now that I've cleaned up my Part Studio by including the mate connectors in the transform commands, those mate connectors can no longer be hidden. Mate connectors that remained static can be hidden, but the ones that relocated are permanently visible it seems.5
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381Ok, so i had a go at this, and it is a perfect storm.
Normally, a user would have at least one of the following;
1) Access to the part feature history - this would enable you to put the mate connector at the center of the bottom face before cutting away the cylindrical opening.
2) Two vertical faces that would allow you to use the 'between entities' option in the mate connector dialog.
3) The ability to derive in a mate connector attached to a part
In the absence of these, a sketch is the way to go.
Philip Thomas - Onshape1 -
Optionschris_8 OS Professional Posts: 102 PROowen_sparks said:I believe that if you hide the transform feature in your feature tree then that will hide the mate connector.
Owen S.0 -
Optionsphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381@chris_8 - YES, you are correct.
'Between' enables you to position and orient a Mate Connector and then say 'but half way between this face and this one'
(this is straight from the help - https://cad.onshape.com/help/Content/mateconnector.htm)
Now I know how to move the mate connector. Is it possible to move the sketch as well?
https://cad.onshape.com/documents/6b714e18e39e7a82c583e9db/w/1b919740fcf6075f60128924/e/7fe629eee1ac35df8f394160
2) Honestly I didn't understand "Between entities" then. I thought of entity as a body, but it can indicate 2 different faces from the same body? That's good to know!
After working with it this evening I realize my issue was misinterpreting the "between entity" box. I expected to be able to specify 2 things in the "origin entity" box, and then expected the mate connector to appear in between the two. But I could only choose 1 entity. I saw the "between entity" box and thought I don't need to click there because I already chose Between entities.
If entity 1 is an origin, I'd expect entity 2 to be a terminal or something. Between is what I expect to happen between entity 1 and entity 2. How does entity 2 get defined as between entity?
I get easily tripped up be wording in OS sometimes. I went off on a rant about 'derived' years ago once I finally figured out what it's really for. I'd been searching through help for Copy part, or Insert Copied Part, or Duplicate Part to no avail. It Derived me crazy
Now I know. Thanks
I'd like to select a point as the between entity. Is there any way to do this?
https://cad.onshape.com/documents/dfaa5483ff7746bf49404630/w/593df3a65236749750bc8614/e/a2695c0099131730ccd2801c
