Problem with tangent mate
Dmitry_Golovkin
Member Posts: 22 ✭✭
Hello dear community,
In folowing design it does not animate correctly.
For some reason the pin going only by half of the ring.
Any advice wold be appriciated.
https://cad.onshape.com/documents/49687b05001ac414fda4f774/w/93dd33c533a805ec3e93e60b/e/c9d4c909bfe4c023123940b9
Optionsandy_morris Moderator, Onshape Employees Posts: 87Hey Dmitry,
I see the problem is a bug of assembly motion that is jumping to an alternative tangent solution. I tried various alternative mate schemes including deselecting limits and using a Fastened instead of Slider, but I get the same issue.
I will open up a support ticket for this.Andy Morris / Head of Product Design / Onshape, Inc.5
Will be wating for the solution.
It's not gonna be spring loaded. Actually it must be wheel instead of pin. Two shafts are not parallel so I made a slider mate to pin be able to stick to sliding surface otherwise in higest or lowedt position the pin could be too long or too short.
