Drag and drop?!
Hey,
I'm trying to drag and drop points, then I think OnS is confused with me trying to window select! It sometimes work but most of the time is just initiates window select.
Is there a keyboard short-cut I should press while dragging?
lougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,011
@Mahmoud The issue is since the construction lines are in a different sketch and the points are on another sketch when you go to click drag, you are not picking your selection but the endpoint of the other sketch. I have purposely laid this a bit off so I can easily select the wrong thing. My guess is your cursor is grabbing that the the click drag. ~Lou
Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6
Make sure nothing else is selected by pressing the escape key once before dragging.
In a new sketch I use points from another old sketch by using the USE command. Then I delete the projected relationship for those points to make them free. Then I try to move the point, it simply initiates window selection and doesn't move them! If you place the points yourself on the sketch moving them is fine, but if you project them first it doesn't work!
Try it, if it doesn't work for you then it's a bug
At first it works perfectly with 5 points selected, then I deselect and then select three points and it doesn't then it suddenly does!
Click show constraints from sketch dialog, something is keeping the point not to move as you wish..
I have suggested to highlight the constraint which is keeping points in place when trying to move in certain direction
There are no constraints... the one was the projected relation which I deleted.
You can see in the gif, it starts moving suddenly without me changing any constraints whatsoever
