Suffix suggestion on drawing
D8_StarpacD8_Starpac Member Posts: 49 ✭✭
In drawing need suggestion(as previously typed by the user)  that have to show when typing in the perfix, suffix on dimensioning
    Do you mean like Chrome remembers previous values for an input?
  • D8_StarpacD8_Starpac Member Posts: 49 ✭✭
    no OS have to remember previous values while edit dimensions in the drawing file
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @D8_Starpac Previoius values?  Undo will undo the change but we do not store every previous value for restore.  Are you overriding the dimension and typing something else in and then wanting to link back to the true size?
    edited January 2019
    To mention the similar hole in face as 4 Holes M8 rather than mentioning each individual hole and for providing suffix for dimensions such as Typ, Both side, etc..
