Converting meshes to solids
CaptainBisquick
OS Professional Posts: 33 ✭✭
Is it possible to convert a polygon mesh into a solid?
I need to use a mesh modeling program to generate my complicated hole pattern. I have to get it into my model, and I see 2 methods:
- Export my model as a mesh and do the boolean subtraction there.
- Export my hole pattern as a solid and do the boolean subtraction in OnShape.
1
lougallo
Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016
@CaptainBisquick since our recent addition to supporting import of STL they can be referenced but currently not for boolean operations. Maybe in the future.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.6
This is my experience, you might have a different need that invalidates my statements above.
In my designs involving meshes, I eventually suppress them in order to speed things up. Having them be a main stream feature in a design would mean a long day at work and would take all the fun out of designing stuff. At least for me.
@billy2 went into detail about converting meshes here:
https://forum.onshape.com/discussion/comment/48685/#Comment_48685
We can boolean a part and a mesh now:
https://forum.onshape.com/discussion/comment/50058/#Comment_50058
I have posted a method that I use to convert meshes to solids here
https://forum.onshape.com/discussion/7124/converting-stl-files-into-a-model-format-that-can-be-used-in-a-sketch#latest
