Enclose on Projected Spline
famadorian
Member Posts: 390 βββ
If I project a set of splines, can I not use these projected splines in the Enclose command to make a surface?
https://cad.onshape.com/documents/6e77b22afe1bdac02e427230/w/bfee167c8c62d3cbf9e2303e/e/66ae6513994178181b15a943
Optionskevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565When you hover your mouse on the red text, it tells you a more specific error: "This operations creates intersecting edges"
If you look at your original sketch, the lines you've drawn are indeed crossing in the far corner. If you zoom wayyy in you can see the endpoints of that line are not coincident. You can make them touch by adding a coincident constraint (select two endpoint and press the I key). After that change the fill feature should work fine.
1
Extrude example:
This is supposed to be a road with a wall alongside it
I also tried to extrude the same set of spline, but that also gives the same error
I don't really want them displayed cause I only use them to make the road. However, if I convert them to construction splines, the rest won't regenerate.
I've got $5 buck on "you'll succeed". Please keep posting progress.
https://cad.onshape.com/documents/7bca6329d1065398cccf45d6/w/267c572473b967c7d8fb05be/e/1e0594d38604f3ef094647df
There's a million ways to build this and best way is to keep on trying. I tend not to project curves and sketches rather deal with the surfaces themself.
Neither way is right or wrong.....
Right, but that's like constructing and then deconstructing harry;) I like to build a cage of splines and then just surface them in the end;)
What are you making? What is this thing?
Is this what your looking for???
https://cad.onshape.com/documents/5daf6a7f162573f5c41ee31d/w/1c11412f7cf36bc020bf7083/e/646ece950fc5f5c533f3ed8d
