Sheet metal DXF export with API
Dmitry_GolovkinDmitry_Golovkin Member Posts: 22 ✭✭
Hello,
It would be cool to export all of the sheet metal drawings with one mouse click.
    Do you mean dxf profiles? because this is possible.
    You should be able to export all sheet metal parts in a single part studio into a zip file
  • caden_armstrong2caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    CADSharp has created an application that solves this issue:
    Renaissance is able to export all drawings from assembly components, and can also do sheet metal flat patterns.
