Browser refreshing below 60Hz in the Performance check.
andy_wilson530
Member Posts: 8 PRO
Hi,
Got a new laptop and running a system check I get the message :
"The performance test was not run because the browser is refreshing below 60 frames per second. Verify that the browser is using the expected GPU and your display is refreshing at 60hz or greater. "
I'm using the latest version of 64 bit Chrome, the laptop has an 8th Gen Intel i5 8250U processor and intel integrated UHD 620 graphics.
Any clues as to how to improve the browser refresh rate?
NeilCooke
Moderator, Onshape Employees Posts: 5,927
The integrated graphics do not have enough power to run at 60 FPS. You can only get those frame rates with dedicated graphics cards. Onshape will still run fine, but might be a little choppy on large data sets.Senior Director, Technical Services, EMEA5 -
andy_wilson530
Member Posts: 8 PRO
Thanks Neil. You're right....Onshape does run just fine. I was just interested to see how much better this machine would perform over my older setup.0
Troubleshooting the performance check
If the performance check was not executed due to a low refresh rate (less than 60hz), or the check resulted in an unexpectedly low triangle/line count, these troubleshooting steps may lead to better results:
