Beginner help needed
Jenny
Member Posts: 1 ✭
I have made a simple part studio with 6 parts. When I bring it into assembly, I am trying to be able to show motion. Can I share the model here so you can see what I'm talking about? I have grouped two groups of parts and then tried to use the revolute constraint. I'm not sure if I need to also use planar or fastened constraints. When I try to do that, it re-positions the two groups of parts relative to each other (I don't want that). I've spent literally hours trying a bunch of stuff and have viewed the tutorials on assemblies. How can I get over the hump?
https://learn.onshape.com/courses/fundamentals-onshape-assemblies
Once you accept the command everything snaps back to where it belongs. (takes some getting used to)
