How to set orientation of Derived Part "Sketch"
nicholas_witham
Member Posts: 17 ✭✭
I have created a document of standard steel sections with 2 part studios, 1 called rectangular Steel the other is Square Steel. I have a configuration table for each sketch to deetermine the size of steel I import to my other documents.
https://cad.onshape.com/documents/d5f4251246e657b5a9441d17/w/e4979b3335fdb9349b3d2c11/e/d6c1d8286eeae3e9e86e2d24
When I bring any of these into my current document (with the derived tool) I would like to be able to choose the plane on which the sketch gets attached to, and/or set the center position of the derived sketch.
Currently I bring the derived sketch into my current part studio, then I have to extrude it, then I can relocate/reorientate the part using the transform tool. This creates extra steps that i'd like to eliminate.
Does anybody see this as being possible?
If so, how?
If so, how?
1
What id like to do now is be able to select the rotation of the sketch to any angle when inserting the derived sketch.
ie, I need to figure out how to have a text box for the user to type the required angle at the time of inserting the derived sketch.
The default would be set to 0 to make it easy.
I have created libraries (Part Studios) for each plane. Inside each library, I have a configuration table (for the standard sizes), and 3 configuration variables (1 for rotation, and 2 for linear offsets).
This method seems to work for me, but if there is a better way, id be happy to learn.
What you are doing sounds like it could be achieved by using beams @NeilCooke . I'm not at my computer, but I'll link the featurescript, a video, and a user made library you can tie to when I get back.
Here is a usermade library with many extra profiles you can reference to (it is a work in progress): https://cad.onshape.com/documents/ad05299d8001b55b1928304a/w/e630f3282c5ec90e2d8432c7/e/ef0605201534ea35869bd331
Here is a video on how to use it: https://www.onshape.com/videos/creating-weldments
Here is a technical briefing from the learning center: https://learn.onshape.com/learn/article/getting-started-with-beams
SuperDerive | SuperDerive (onshape.com)
I use it all the time to add our logo into sheet-metal parts.
In the picture here I don't even need the sketch, just add an in place mate connector and rotate/transform right in the same feature.
Of course I needed to scale also, (maybe that should be added to SD..)
So I had one extra transform/boolean to finish
It's a very useful feature, defiantly a must-have on your tool bar.
