Extrude, Keep Edges
famadorianfamadorian Member Posts: 390 ✭✭✭
edited February 2019 in Community Support
If I extrude something like this, the edges disappear.
What I mean is that I've specifically made cuts here that I want the extrude to keep.
If that's not possible, then I'm not sure which workflow I should be using, cause this is a cabinet and when I attach the door to this cabinet in the assembly, I don't have the edge that I want to attach it to.
https://cad.onshape.com/documents/a3610a44fdd7c3eb8128d329/v/ef5ec9cd30c496a8b6f3635c/e/361a1676f80cbe423bcba51c
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,889
    If you’re using “add” then any intersections will merge with the rest of the model. If you use “new” it will keep the edge. I think that is what you are asking?
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    Ok, I tried using "New", but it complains that "No merge scope selected", even though I checked "Merge with all"
    You image says “add”?
    Right, but I was using "new"; sorry, was confused.
    However, when I use "new", the edges disappear.
    Here's the result of using "new"; the edges I want disappears from the final extruded result
    I want to somehow get this edge, which was in the sketch
    I need this edge to put the door on.
    I can ofcourse make a whole new plane and add some geometry there, but if there is a way to get this edge, it would save me that step.
    That or after the extrude, split the front face with the planar faces created by the extrude.
    https://cad.onshape.com/help/Content/splitpart.htm
    Thanks;)
    Just as another alternative, there is a custom extrude feature that does that.  Now who wrote it?  I think it was a Jake Someoneorother, hang on a minute I'm sure it will come back to me :*
    O.S.
    That's the one, clever chap that Mr. J.  Someoneorother
