Extrude, Keep Edges
If I extrude something like this, the edges disappear.
What I mean is that I've specifically made cuts here that I want the extrude to keep.
If that's not possible, then I'm not sure which workflow I should be using, cause this is a cabinet and when I attach the door to this cabinet in the assembly, I don't have the edge that I want to attach it to.
https://cad.onshape.com/documents/a3610a44fdd7c3eb8128d329/v/ef5ec9cd30c496a8b6f3635c/e/361a1676f80cbe423bcba51c
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@famadorian
You will have to do this as two extrude features. Sketch regions that are touching in an extrude feature will automatically merge with each other, no matter what boolean option is set. Do the extrusion of the outer box first, and then do a second extrusion of the shelf, making sure to set "New"Jake Rosenfeld - Modeling Team5
However, when I use "new", the edges disappear.
I need this edge to put the door on.
I can ofcourse make a whole new plane and add some geometry there, but if there is a way to get this edge, it would save me that step.
https://cad.onshape.com/help/Content/splitpart.htm
( https://cad.onshape.com/documents/cf2ebd36a36695408b9650a9/w/8e89a7bc10431e16fe2fceb7/e/b34a987c9a30ef7498b53f66 )
