Improvements to Onshape - February 11th, 2019
bradley_sauln
Moderator, Onshape Employees, Developers Posts: 373
We're continuing to dive into 2019 with another big update involving highly-requested improvements! Let's get started.
CAD IMPROVEMENTS
ASSEMBLY CONFIGURATIONS
Onshape's unique approach to configurations using multiple independent inputs is now available at the assembly level.VARIABLE AUTOCOMPLETE
Variables will now appear for autocompletion in feature dialogs, sketch dimensions, and a number of other places. Other helpful math functions such as rounding also autocomplete; for more information take a look at our help documentation.MIRROR IMPROVEMENTS
Mate connectors can now be used as a mirror plane in Part Studios.DRAWING ANNOTATION IMPROVEMENTS
You can now add leaders (even multiple leaders) to GD&T frames, as well as multiple leaders to weld symbols and surface finish symbols.HOLE CALLOUT SNAP IN ONSHAPE DRAWINGS
Hole Callouts will now snap in Onshape Drawings. This makes them easier to align for improved Drawings organization.SECTION VIEW DEPTH
You can now define the depth of Section Views in Onshape Drawings.IMPORT IMPROVEMENTS
Onshape now supports importing the following file types:- ACIS up to 2018 1.0
- Solid Edge 2019
- SolidWorks 2019
- Unigraphics NX 12+
ENTERPRISE IMPROVEMENTS
SINGLE SIGN-ON WITH GOOGLE
Enterprise administrators can now enable single sign-on (SSO) to Onshape through a user's Google account. This enables users to sign in with Google but does not include identity management with Google. SSO is available for Onshape's web and mobile platforms. Administrators can enable SSO under their company authentication settings.
5
And it looks amazing, too. Can't wait to start working with it.
Now, to watch that video again....
Being two weeks into a major CAD upgrade at our daily grind, which has us at a standstill while waiting for functionality to return, and comparing to this update...
Just superb.
Torus Developments - Mobility Engineering
Burnie, Tasmania, Australia
+61-402-822-410
torus.aus@gmail.com
and variable naming
and others too
What a great way to start workday!
ps. I'll probably install this update/service pack later since I have important project on the works and can't risk it with updating process - No wait, it's already there; came in while I was sleeping. How awesome is that?
Will there be a possibility to import assemblies to FS?
The new Assembly configurations looks amazing!
Nice work
I still miss 3D sketches though... We really need this feature for complex modelling.
Is the example available in a tutorial? I would like to go through a tutorial if possible.
https://learn.onshape.com/courses/introduction-to-part-configurations
https://learn.onshape.com/courses/advanced-part-configurations
Custom Properties
Of course, you can configure Custom Properties, just like Part Studio configurations. This is fantastic. Except: It seems that you can't configure the Name property of an Assembly...Is this a limitation? Or is there another way to end up with a different Assembly Name for different Configurations. Other properties seem to be available, but not Name.
Obervation regarding Release Management & Versions:
When you Release a configured assembly, it Releases ONLY the active configuration (or the config that you select). The Released Assembly's configuration is fixed in any downstream documents / instancing. (You can, of course, release more than one Configuration of the Assembly).
When you Version a document, the Versioned Assembly's configuration can be changed in downstream instances.
@NeilCooke can you confirm this is the desired behaviour? It makes sense to me...and now have to rationalize my workflow with RM and Versions...
Thanks
Romeo
If I am reading your observation about release management correctly, then you are correct about how assembly configurations work for versions vs. revisions.
edit:
You will also see this same behavior with parts from a configured Part Studio.
Sr. Director of Product Definition. UX and Support
I added a little edit to my post before I realized you had responded.
Can you comment on how we can Configure different Name custom property for Assembly Configs?
@owen_sparks
I agree with you - and this is part of the larger discussion on how to get Release Management to work for us. We're going in a good direction though.
