How to Import multiple Parasolids/STL/Step files into an Assembly
joshua_gibsonjoshua_gibson Member Posts: 3
I have multiple Parasolid files that I would like to make an assembly with to see how the parts fit together. Is there a way to do this in Onshape?
I tried inserting the Parasolid into an assmebly but it wont allow me to. If I select the Parasolid I want to insert the green check mark stays dimmed.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Hi @joshua_gibson - you have to translate the Parasolid files into Onshape parts first. In your open Document, go to the + menu (bottom left) and select import, then select all the files you need. A Part Studio will be created for each imported file. You can then insert the parts into your assembly.
  • joshua_gibsonjoshua_gibson Member Posts: 3
    Hello @NeilCooke. Thank you for the reply. I tried that and its still not allowing me to insert the part into the assembly. I created a new document and imported the Parasolid and tried to insert. Here's a screen shot of what I got.
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    @joshua_gibson Is there a part in that part studio?
    Nope!
    As they said on Mythbusters "There's yer problem!"
    @joshua_gibson it looks like your Parasolid might be an STL or other mesh, not an actual part.
    O.S.
