Drawing problem with the position of the projected views
mauricio_hernandez
Member Posts: 11 EDU
when a view is projected, it projects the opposite side of the origin view
john_mcclary
Member, Developers Posts: 4,052 PRO
Everything is projected with 3rd angle projection.
I cannot find a setting to change it to 1st angle.
If you need to, submit an improvement request.
Otherwise a work around would be to project a side view to the right (for example) then manually move it to the left of the original view.
I believe that is basically the same thing.
5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,987
ANSI drawing formats are 3rd angle, ISO formats are 1st. Best to create your own.Senior Director, Technical Services, EMEA6
@john_mcclary
When you create the drawing, you can use a custom template and choose between 1st and 3rd angle projection
