Drawing problem with the position of the projected views
when a view is projected, it projects the opposite side of the origin view
    @mauricio_hernandez
    @john_mcclary
    When you create the drawing, you can use a custom template and choose between 1st and 3rd angle projection
  • mauricio_hernandezmauricio_hernandez Member Posts: 11 EDU
    Thank you both for your very quick response. that was very useful for me.
