Or with Parameter Pattern
Do you also have ISO profiles?
https://cad.onshape.com/documents/4a9705b2f1668dc749e41c80/w/42533b194af5e567e3461430/e/9a337db55917e7a2d4f0038f
https://cad.onshape.com/documents/e15c2c668d138f01242d0c80/w/0664d65a957c7bfba7cfbddd/e/bd6831589391741e327fec75
The profiles need 3 levels of depth with the last one's "name" : "size" (the "displayName" can be anything, but the code looks for "size" in the level under "profile", so you must have both). Here is your code modified:
const NZ_Steel = { "name" : "profile", "displayName" : "Profile", "units" : millimeter, "entries" : { "UB" : { "name" : "size", "displayName" : "Size", "sequence" : "C", "entries" : { "150UB 18" : { "points" : [0, 0, 678.6568] } } } } };I keep thinking I want to do a set of profiles for Australian steel sections, the ISO ones, unfortunately don't match our sizes. I think the NZ standards are the same as the Australian, if so, maybe we could collaborate on a common library and get @NeilCooke add it to a future version of the original beam script the same as he did with the ISO ones.
Here 's what I want to be included.
http://www.steelweb.info/
or basically what these guys sell
http://www.orrconsteel.com.au/products/tube-pipe/structural/square-hollow-section
@mbartlett21 have you seen any Australian steel section done for the beams FS?
Having said that, please share the URL of your document and I will take a look.
@Cris_Bowers - I understand it is a pain. I use a label called Profiles to find them (marginally) quicker.
Hi, Thanks It's working as expected with "custom beam" Option.
https://cad.onshape.com/documents/cbcb5406bdf8ec15703a9e9e/w/025f41c07b76ffc79326b010/e/80ef60b33449e47bc3e6a01e
It supports weld gaps, manual loop selection and trimming. Tangent loops are merged into a single section.
It also includes a cut list feature, which creates a list of the created beams with their length that can be exported to CSV (Bent CHS/pipe cut list is not supported)
If you choose manual selection, you can specify an angle for each loop as such. It is just the profile and offset currently that can't be changed in manual selection.
I am wanting to make a separate 'Joint' feature that lets you select sets of faces and have it join them for you.
Also, finally, the Australian Beams feature (version 3 now) is now located at https://cad.onshape.com/documents/1932527edac323470b3700c5. (The reason for the different documents is that I created a new one for each breaking change. Both breaking changes were to do with profiles).
If you are wanting to update from an old version, you should make a note of the profile(s) you had and then update it to the new document, then finally update it to the latest version in the new document. (afaik apart from the profile, there shouldn't be any breaking changes there).
