Helix, Unwrap to Sketch
william_holden959
Member Posts: 34 ✭✭
I'd like to be able to draw a helix, flatten it to a sketch, alter it and then have it convert back to the helix with the changes. Sketch Wrapper is a great solution, but I'd ultimately I'd like to use a helix to base it off of. Thanks!
To clarify the other comment about the profile of helix is kind of a different topic, but theoretically the concept of a helix could be expanded to include square shapes or any closed loop for that matter - it shouldn't have to just be for circles (or cylinders).
I do this for my projects and it works very well.
for example adding extended tabs for roll form feeding:
Circled areas were added with a flat pattern sketch
Probably so. I found a work-around and the feature would probably get limited use.
