Self-intersecting loft / sweep
piotr_smektała
Member Posts: 5 ✭✭
Is it possible to create such a geometry using sweep / loft function in Onshape?
Using such a set of sketches:
I can't figure out how to do that.
Am I missing something or that is a big flaw in functionality?
NeilCooke
Moderator, Onshape Employees Posts: 6,006
Parasolid does not permit self-intersecting geometry in a single feature but you can make it in two or more features if you really need to.Senior Director, Technical Services, EMEA5
TVP, Onshape R&D
TVP, Onshape R&D
Could possibly test for fail condition and say double the number of segments as see if it passes then?
TVP, Onshape R&D
See https://cad.onshape.com/documents/990065be862441f76bbd90eb/w/29b6322a1e8e7dab00dbdf74/e/ab266ba0e372b4d738118cf3
It is just one sweep
Thank you so much for this remark about body/face difference.
