Music Box on ice
Hallo Onshape Forum,
I made some further progress with my Music Box (build after a model I purchased on Amazon) but can't progress it much further with my knowledge in Onshape.
- I am missing the functionality to sketch on circles
- From what I see is that you can't sketch / modify imported objects
- Illustrator sketches can't be imported and used for modelling
- I have no clue how to model this wheel (bigger one)
Until above functionalities are included, and I am sure they will come, I put this project on ice but leave the file open for the public in case someone like to play around.
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
Sorry @tarek_mustafa I typed my email wrong so didn't get the share try babart77@gmail.com
See this gif, this is how I would to the radial pawl.
And finish with a face partern1
Share me in with babart77@gamil.com and I will have a go. (no stress if you don't want me in your doc but the collaboration features of Onsahpe are really cool)
https://cad.onshape.com/help/#web-help/helix.htm?Highlight=sketch
I suppose you could make the cone a really short (absurdly short) so that the helix generated doesn't have much movement in the "z" direction. Then extrude the spring on that helix.
First, focus on the black pawl wheel in the image below (the upper red arrow):
Let's assume for the sake of argument that the teeth of the pawl are not linear, but rather radial (i.e. the lines that make up the crests and valleys of the teeth don't project normal to some sketch plane, but rather radially outwards from the major axis of the drum. You will need to both create a line on the outer diameter of the pawl wheel, and have a cut/extrude that is normal to that sketch at every point along its length. Can you come up with a general procedure for modeling this in OnShape? Can you do it with a face/body pattern, so you don't have to model all the teeth? For convenience's sake, assume that there is a hole through the center of the pawl wheel that is 1/2 the OD of the pawl wheel, so you don't wind up with some wacky self-intersecting geometry at the center.
(@BruceBartlett - I think this is what you were alluding to above - if you wouldn't mind creating a sample model you can share publicly, that would be awesome!)
Very cool, I think this can also work like a chat tool if you click on a reply after the first comment rather than Adding a new comment. It needs a little bell/icon to let you know when a comments is added, not sure if that's there yet.
I
Here's what I've got so far. Also is there any chance I could go access to the assembly so I could resize and detail my component more?
Thanks,
Vince
Creative and Technical Skill Development Coach
Design Inspiration
LinkedIn Bio
