Improvements to Onshape - April 15th, 2019
Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 39
edited April 2019 in New in Onshape
We’ve already reached our fifth release of Onshape this year. Take a look at some of the new features below.
CAD IMPROVEMENTS
REPLACE IMPORTED GEOMETRY
You can now directly replace imported geometry within Onshape. You can update the file by right-clicking on the import feature or by selecting the "Update" button on the tab in the new CAD Imports folder.
https://onshape.wistia.com/medias/8merpuiifo
SHEET METAL HEMS
You can now easily create hems, using a new dedicated Sheet Metal Feature.
https://onshape.wistia.com/medias/pfc4dzhduz
CURVATURE COMBS ON CURVE CREATION
You now have a new option to view the curvature combs of previewed edges while creating features such as Bridging curve, 3D fit spline, and loft. These curvature combs update dynamically as you modify the curves.
https://onshape.wistia.com/medias/e0qzphe9fo
IMPROVED HLR PERFORMANCE
You’ll see improved performance when creating drawing views in the Hidden Lines Removed display stye, particularly when rendering organic shapes which create spline-silhouette edges.
DRAWING TABLES - OPTIMIZATION OF FIT ON DOUBLE CLICK
Within a drawing table, a double-click on a cell border will auto-size the row or column to fit the contents.
EDIT SECTION CONTEXT MENU ITEM (SECTION VIEWS)
You can easily edit a section view through a more discoverable “Edit section” option in the right-click menu of the section view itself.
INDUSTRY SYNONYMS ADDED TO ONSHAPE HELP
While searching the Help, you may now query for synonymous terms from other CAD tools, and the results will return the appropriate Onshape equivalent. As an example, searching for “move” will now also display Onshape’s Transform feature.
PREFIX FOR CHAMFER DIMENSIONS
You can now add a prefix on chamfer dimensions. This can be useful for calling out quantities, much like you would on a hole callout.
PROFESSIONAL IMPROVEMENTS
UPDATE PROPERTIES WITH API ONLY
You can now create custom properties that are locked in the user interface, and only editable via the API. This can be configured independently for versions and workspaces. This is useful for managing third-party integrations.
ENTERPRISE IMPROVEMENTS
BLOCK DUPLICATE DOCUMENT NAMES
Within an Enterprise, you can now prevent users from creating documents with a name identical to that of an existing document. This feature is configurable using a regular expression, so you may choose what is enforced as a matching name.
  • Cris_BowersCris_Bowers Member Posts: 281 PRO
    BOM resizing isn't working correctly for me. It's shrinking some columns causing the text to wrap and it increased the width of a column that I intentionally have wrapped text in, but not to the point of unwrapping the text. I already contacted support about it, just wondering if others experience the same behavior.
    Great work!!
    I will test the import geometry improvements and ( finally  :# ) the sheet metal hem
    Un saludo,
    Happy Monday for sure!  Replace CAD and curve combs are great improvements for us.  Thanks Onshape team!
    www.accuratepattern.com
  • romeograhamromeograham Member, csevp Posts: 715 PRO
    Thanks for another great Update. It was hard to get through the weekend knowing that it was imminent...
    From the changelog:
    • New FeatureScript: Operation to imprint shadows (opSplitBySelfShadow)
    I have been hoping for a FeatureScript (or native feature) that functions similarly to SolidWorks Silouette Split Line with Draft:
    The result:
    The split surface on the curved shoulder is the result of "pushing" the Line of Draw plane (purple, above) through the part, and giving the "silouette" line where the plane crosses the surfaces....but in the location that would give a 6-degree draft relative to the LOD plane.
    This is a feature that I used a lot in SW, but now have a series of funny workarounds to get the same split in Onshape.
    Would this new FeatureScript  (opSplitBySelfShadow) be able to help with this type of feature?
    Thanks!
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,237
    edited April 2019
    romeo_graham392 Actually, for that, you want the opSplitByIsocline from the previous update.
    Here's a featurized version: https://cad.onshape.com/documents/5370e14526610dcdfe34a4a4/v/cf7da8ecbedcc162cc04499f/e/de85d2a2f38b7dee01159ab0
    There are so many cool custom features out there!
    Ilya just showed you Silhouette Split, here is another fun one - Silhouette Projection -
    https://cad.onshape.com/documents/447c6fe48283e84c4c382e67/w/21976dd0fa3c061779d3d951/e/952b0a5aee92f9251ac36bcc
    Philip Thomas - Onshape
  • Andrew_Enslow_3DSAndrew_Enslow_3DS Member Posts: 40 ✭✭✭
    Thanks for another good update! I really like the Import method - that is a big help when working in two cad systems! Also thanks for the hem. I'd requested that one a while back and I'm happy to see it come to life.
    Thanks for releasing quality features regularly!
    edited April 2019
    @ilya_baran that is exactly what I was looking for. I missed it in the last update (I haven't gotten into working with FeatureScript yet...).
    UPDATE: I see that you made that FS today: THANK YOU!
    @philip_thomas I was aware of that one (which I do use in another type of feature) but without the Angle setting that Isocline has, it's not what I am after for this feature.
    Thanks guys!
    Romeo
  • EricGauthierEricGauthier Member Posts: 73 ✭✭✭
    Great job again!
    @romeo_graham392 - I did not mean to imply that the Silhouette Projection custom feature would solve your specific need, simply that it was a related capability that you or any of the many viewers of these announcements might be interested in :)
  • gerhard_swanepoelgerhard_swanepoel Member Posts: 29 PRO
    Again, improvements do not disappoint!
  • brucebartlettbrucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,146 PRO
    Thanks for the improvements. Replace imported geometry is a nice improvement I wasn't expecting but will be really handy.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,959 PRO
    Import geometry is now updateable! sweeet
    Double click table width, niiice
    Great work as always
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 889 ✭✭✭✭✭
    Great job on adding hems and replacing imported geometry.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
  • GlendonKuhnsGlendonKuhns Member, csevp Posts: 38 PRO
    Thanks for the automatic Imports folder. It's a small feature that will save a lot of time.
    @ilya_baran
    You have made my day!  This routine to find split lines is what I have hoped from Onshape since beginning.  In patternmaking we call this 'the parting line'.  Having a tool to get these curves is critical for much of our work.
    Once that curve is made - the split parting surfaces need to be generated.  Here is one way to do it but I would like something more elegant and correct.  It would be nice if extruded vertex curves could be used for 3D normal sweep. Or extrude from a 3D curve.
    What ideas do others have for these free form surfaces 'normal' to the 'isocline' type curves?
    edited April 2019
    check this Norml rib FS, made it for creating sweeps of line normal to the reference faces along the contour
    @konstantin_shiriazdanov
    That is exactly what I needed! Your FS did in one step what took me 7 and it is better surface.  I suppose doing things the hard way has taught me more about surfacing.  ;)
    Thank you immensely!
    @bruce_williams glad it helped, I had problems sweeping along multiedge contour at once so I used internally booleanPlus feature by @MBartlett21 for joining pieces of sweept surface for each edge of the path.
    @bruce_williams
    One thing to keep in mind is that Konstantin's feature extends the curves in the direction normal to the surface, while radiate surface (which, granted, needs an accuracy improvement) extends the curve in the direction perpendicular to the curve that lies in a given reference plane.  I'm not sure which is desirable in which cases, but they are different.
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194
    edited April 2019
    We also released two new technical briefings in the Learning Center:
    Working with Third Parties Using Onshape Enterprise- Learn workflows for working with clients or suppliers when using Onshape Enterprise.
    Release Management FAQ- Understand frequently asked questions when getting started with release management.
  • Cache_River_MillCache_River_Mill Member Posts: 225 PRO
    Great work Onshape team!
    Thank you.
  • sean_blanchardsean_blanchard Member, User Group Leader Posts: 49 ✭✭✭
    I love the improvements to the Chamfer tool. I would love to still be able to add a "Suffix" to the feature as well. However, I am pretty happy with the tool. Thanks Onshape, I continue to look forward to the improvements you're making to the software.
  • fredrik_1fredrik_1 Member Posts: 27 ✭✭
    edited April 2019
    Thanks a million for update imported geometry! Just tested it and it works pretty well.   :*
