Hide Other Instances
After I've hit "hide other instances", is there a way to "unhide what I just hidden"?
I see there is a "show all", but this function shows all, even though I've spent time hiding stuff, so now I have to hide certain parts all again;)
john_mcclary Member, Developers Posts: 3,952 PRO
You can also click on parts and select isolate, which will make everything transparent. Then you just close the dialogue box, or adjust the slider to unhide parts next to/connected to your selected part.
6 -
famadorian Member Posts: 390 ✭✭✭
john_mcclary said:You can also click on parts and select isolate, which will make everything transparent. Then you just close the dialogue box, or adjust the slider to unhide parts next to/connected to your selected part.
Thanks;)0
- 'Undo' the last hide
- RMB/show all (everything including parts, sketches, planes, mate connectors)
- RMB/show all instances (all parts/surfaces)
- In an assembly you can create display states that store the hide/show state for later use in drawings
I hope this helpsOk, I'll try.
Thanks;)
