Holes Wizard request
Hello everyone! I'm a new OnShape user. Im very excited with this innovative project!
Trying it with some designs, I note that no hole wizard have been developed. The lack of any automated tool for threaded/countersunk/counterbore standardized holes is a big obstacle to OneShape becoming my primary CAD soft.
I hope this feature will be incorporated soon!
Typing "hole" into the help yields this...
https://cad.onshape.com/help/#hole.htm?Highlight=hole
You'll see it does ANSI and Metric versions of what you're looking for.
Cheers, Owen S.
We are a different CAD system from where you are coming from and thus have tools, features, and workflows that are not exactly the same. With a little time to explore the product, you will discover what you are looking for
Twitter: @bradleysauln
Also having trouble placing starting points on an inner diameter that was built from planar sketch extrusion, trying to generate a helix and a triangular cut path from scratch, but that's probably just newbiness.
Sounds like you are trying to create an internal thread? Create the helix, then create a plane using "curve point" then sketch on that. Note that, unless you are 3D printing, there is no need to model threads.
