Filet Limits and Where Do They Originate?
in Drawings
I have an extrusion that fails to filet at a very small number and I believe it's because of a single very tight radius curve. Does that radius of the curve have a direct bearing on the filet size? Let's say the radius is .02 in. Is that the approximate limit of the filet size as well? Or is the correlation more complex?
john_mcclary Member, Developers Posts: 3,948 PRO
Edit: Original answer has incorrect Information
Better answer: The problem is the small corner fillets need to come after the overflowed fillet.
I this case, your upper limit is equal to your part thickness,
anything larger fails because Onshape does not have "fillet overflow" meaning it will continue to fillet until the shortest face reaches "zero-length". I know SW now allows overflow so it will just end up making a fillet that is tangent to the larger face, and tangent to the lowest edge of the shorter face.
The line marked A is the shorter face I'm referring to.
You can see when your fillet is equal to your height, then there is no line remaining (zero length)
the last image is probably what you were expecting, which is what SW refers to as Overflow.
I smell an improvement request...6
https://cad.onshape.com/documents/c7ac382255c4440e75bf4ef3/w/1f3e5ec88beba41434f1492d/e/4acce76f9471456354ecfedd
After changing the sketch and ensuring that the tangent constraints were applied correctly it seemed to correct the limits I experienced. For now I think the question has been answered and want to thank you as well for the replies.
the small fillets are making it zero length, do the fillets second @larry_hawes
