drawing materials and weight
franco_otaolafranco_otaola Member Posts: 23
edited October 2017 in Community Support
hello
it is a simple question i couldnt find the answer.
i have assigned the material in this case steel for a piece (after finish a drawing of the piece) and when i actualisated the drawing i was expecting that it would put the material and the weight of the piece in the low part of the sheet (there is the two sections in the template i used)
but i cant succes to show this to properties i dont understand what to do to be able to modify this without writing it manually
EDIT: i have succesfully donne for the title and material (semi automatic way by cliclink in the text book and select insert drawing property or part property for title and material by i couldnt find the way for the weight)
so still needing help for the weight part in the drawing template
thanks
    edited October 2017
    I don't think there is a way to do weight Yet.
    Materials need desperately to be improved. Not custom materials, so you're stuck with whatever is on the list and it's density for your accurate weight and there also need to be a way to add stock materials ie. material is steel (steel is the global property valve) but you want to also spec the size/shape/length/etc for your drawing and BOM. I hope we see improvements soon. Lots of votes already on this, add your vote here  https://forum.onshape.com/discussion/comment/32573#Comment_32573
    https://forum.onshape.com/discussion/6881/apply-material-to-parts-without-material-from-within-the-mass-properties-dialog#latest
  • Kalvis_AbeleKalvis_Abele Member Posts: 2 PRO
    Still no updates to this issue?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,001 PRO
    You have to use a featurescript to set your weight, based off density and volume. Then store the result in a custom property
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 566 image
    What's New in Onshape's Latest Update (October 20th, 2018)
    The custom FeatureScript for this can be found here:  https://cad.onshape.com/documents/0ce17b6f297c6baae1ea4f31/w/bf0718cfe1b17361423f8bb1/e/0780443bed0d39745f999034
    This is again not the intended long term solution here, but will give users these abilities today.
