Assembly rotation question. How to stop motion when two pieces hit?
len_2len_2 Member Posts: 8
I have an assembly with what I'll call a swinging arm. It rotates about a point at one end. I want to stop the arm's swing when it contacts a pin, but right now the the arm just passes through the pin and and can swing 360 degrees. How do I make the pin block arm rotation in the assembly?
    Given that OnS is an immature product, still in beta at the actual moment, which does not yet boast limit mates, the best you can currently do * is to set up two mates which stop the mechanism where the arm reaches its physical limits.
    Suppress one or other to simulate the arm stationary at  each of those limits, or suppress both to revert to free swinging with no limits.
    Limit mates are quite high on the list of priorities, and my guess is they will most likely be implemented before public launch, because they are almost indispensable to mechanism design.
    * AFAIK - I would be delighted to be introduced to a better workaround
    The other possible solution is physics (parts of mechanisms which interact realistically). Given that physics engines are available "off the shelf", and have a very simple user interface, I guess it's conceivable such a capability could be incorporated ahead of the less glitzy, but (at least in the past) generally more useful limit mates.
    @Len there are no mate stops yet. Hopefully we see this given time.
    What you do have is a reset on the revolute mate - RMB on the mate in the tree and click reset, this quite handy to re-position part back to default position. If you want to change the default position you can and rotate the mate connector.
  • len_2len_2 Member Posts: 8
    One again, thanks for the very prompt response. This limitation is not a show-stopper for me right now. I just assumed I was missing something.
  • TamuTamu Member Posts: 1 EDU
    Do you guys now if they added a feature for this problem?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    Yes, you can limit the travel of individual mates.
