Feature Request: accepting "#" (hash) for directly typing sizes and using variables
Currently when drawing something in a sketch like an line you can directly type an number and it will size your thing to that size.
But you cannot type "#" (hash) directly to use variables for that sizing, it just gets ignored. You first have to type an number:
delete that and now you can type the "#" for starting with variable names.
The fastest way to use variables for me is typing "0", backspace and then I can write "#" in it.
This is very annoying especially because I like to use variables for nearly everything.
Please make that you can type # directly.
You should add this under Improvement Reuests instead.
That way users can vote it up, and Onshape will add it to the list
@lougallo
Can this be moved?
https://forum.onshape.com/discussion/11784/accepting-hash-for-directly-typing-sizes-and-using-variables#latest
