Mate connector for slider mate for tube roller on configurable diameter tube
alnisalnis Member, Developers Posts: 452 EDU
I've been scratching my head over this for a bit now, so I thought I'd ask about a particularly weird case for defining a mate connector. Here is the part I'm importing: https://www.servocity.com/0-250-acetyl-press-fit-tube-roller.
Here is an image of a similar part (with built-in ball bearings) as an example of how the part sits on tubing:
What I'd like to have would be a mate connector for a slider mate with the tube which the roller sits on where the mate connector's position is defined by a configuration variable for the tube's outer diameter. Here is a document in which I mock up part of the target behavior: https://cad.onshape.com/documents/6569ec2e7e44e8d68bc3e677.
A simple slider mate is probably good enough in this situation because the roller may slip, so modeling a relation between its rotation and translation along the tube wouldn't be mechanically meaningful (and would add complexity/difficulty). The current document's demo assembly is configured with a table with different mates for each of the diameters of tubing. However, the goal is to have just the roller and mate connector with a configuration variable for the tube diameter so that it can be "dropped in" and used with any diameter pipe (within the 1/4" to 2" limits of the part).
Sorry if this question is a bit wordy/unclear, and thank you in advance for any help!
    FeatureScript Unified Spline will take multiple lines and arcs, and create a single spline through all curves which you can use for e.g. sketch tangent constraints. This has all the benefits of @NeilCooke 's solution, without the need for approximation.
    edited June 2019
    I usually create a sketch of a circle tangent to the wheel, then plop a mate connector on the center of the circle.
    Then a simple slider is good.
    You can configure your sketch to have different diameters and that's it.
  • alnisalnis Member, Developers Posts: 452 EDU
    Thank you for your response!
    This is a bit of a trickier situation because the profile of the roller is an arc, a line, and another arc, so a single circle cannot cover all diameter cases with a single tangent constraint as far as I know. As the diameter grows, it comes into contact with different geometry.
    Sorry if I'm not articulating this well!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,845
    The easiest thing to do here would be to eyeball a spline over the roller profile and make the circle tangent to that.
    https://cad.onshape.com/documents/585135a07a22a6cf2a538a57/w/84f2e412f5bce7f65d55a23d/e/1db576bed76718b866aa9189
    If all the faces are tangent, maybe add fillets. Could you just composite curve instead of eyeball spline?
    Thank you for your time and responses!
    I think that in the end, I'll try to create a one-off FeatureScript because it will provide an exact solution and it will be good practice. Alternatively, if that doesn't work out, I might just go with a clunkier configuration table (with ranges for the diameter to select the circle/mate connector) and configuration variable (with the exact diameter of the tube).
    Thanks again!
    Thank you so much! That is exactly what I needed!
  • EvanReeseEvanReese Member, Mentor Posts: 2,339 ✭✭✭✭✭
    This is a very useful feature. Can it work for closed splines as well? I was having trouble
    Independent Onshape Consultant | Industrial Designer
