Is there a way to delete all in the dialog boxes?
a_elias
Member Posts: 2 ✭✭
If I have a sketch with 20 parts, such as an imported DXF and I want to make an extruded surface from the sketch, I have to click each sketch part.
If I update the DXF for some reason, I have to delete all the previous sketch parts before I can begin selecting the new sketch parts.
Is there a way to remove all in the chamfer, fillet, extrude and other dialogs?
NeilCooke
Moderator, Onshape Employees Posts: 5,974
Not sure I understand fully, but if you import a DXF into a sketch that has multiple contours/profiles just select the sketch from the feature list to extrude them all in one go. If you do need to remove all selections, press the Space Bar.Senior Director, Technical Services, EMEA5
@a_elias
You can clear selection by right clicking in the graphics area and choosing "Clear selection"
So you don't need to select white space.
