Importing 3D DWG to Onshape
in General
Hi all,
A client has sent me a 3D DWG - can open in a DWG viewer and it rotates, etc so it's drawn in 3D. I am not sure if it was actually from a parametric 3D software or just drawn in 3D. Is there a way to tell, and then is there a way to convert it for importing into Onshape?
Thanks!
Thanks!
1
NeilCooke Moderator, Onshape Employees Posts: 5,884
Hi @daniel_cook - 3D DWG is not supported, but your client should be able to export in ACIS format (*.sat) and that should work fine.
Senior Director, Technical Services, EMEA5
You could also consider this solution for DWG 3D information. Graebert has a DWG solution in our App Store for situations like this:
https://appstore.onshape.com/apps/Design/A6WITSUWP2GZQN5BX6HHCM2TNBVBEDABC34MIUY=/description
