Beams 2.0 error
Dmitry_Golovkin
Member Posts: 22 ✭✭
Hi Guys,
Recently I started to experience problems with Beams FeatureScript. When I try to pull the manipulator arrow to reposition the beam it started to report error. Probably it started after the latest update FS but I'm not sure. FeatureScript notice does not report anything. It does not depend on profile. Can't find way to workaround. I use Official V8 version.
Document URL is https://cad.onshape.com/documents/b4cbf1e8ad2a900ecfcec7c4/w/440ac939c042138bc444207d/e/1ac794b7d7d543e6138441a3
Any ideas would be appreciated.
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,417Admittedly, there have been a few reports about this. Official V5 is the one that has been there for the past year. V6, V7 and V8 were all made on the same day. I’ve looked at the code and can see nothing that I’ve changed that would affect the regeneration of the feature. I have also seen the feature somehow fix itself (when the original doc has been shared with support). I will take another look. Although the blue link icon may be annoying, you should continue to use V5 until I can get to the bottom of this. Sorry for the inconvenience.Senior Director, Technical Services, EMEAI5
Optionsilya_baran Onshape Employees, Developers, HDM Posts: 1,178This should be fixed now. Please post if you see that behavior again.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc6
I have contacted to support as you advised.
@Dmitry_Golovkin I have tested it in your Doc and it works (I also tested it in another user's Doc which was displaying the same behaviour).
Everything is working fine after update to V9.
Sorry that's not all ). In one my document everything become ok but in other one the problem still exists.
It didn't marked outdated scripts. I updated everything manually. The first I updated script in toolbar after that every instance one by one. It didnt show blue chain. In one document it worked in another one it didn't.
For some reason each beam picked up custom profile sketch older version than "main". After I manually linked the latest sketch to each beam everything started work properly.
