how can i edit an imported solidworks file?
adva_eshel
Member Posts: 4 EDU
i imported solidworks file, it says that the translation completed.
how can i work on the it?
when i double click it, it doesn’t really open the file in a work space, instead i see this-
thanks for ur help
thanks for ur help
but when I double click it (to enter and start edit) it shows me the file's details and not getting me into the workspace. like in the pic attached.
why is that?
and thanks for the quick response:)
Like Chris says, you'll have dumb solids. This hasn't been a problem with my SW imports.
I've set it up so I can go back and forth sending files back to solidworks from onshape and work full circle. The newer assembly inside onshape drives everything and is the master of this onshape & solidworks combo. File names and structures pass back & forth. I've been working on properties moving from each system but haven't gotten this work. Assigning properties is much easier in onshape and wish I could shove them back down into solidworks.
