Boolean not returning valid part
naregjannaregjan Member Posts: 6 EDU
I have a boat that I'm trying to model based off of four lofted sketches. I've been trying to hollow it out; I tried using both shell and thickness to do so. In either case, whenever I try to take the top of the boat off using any sort of boolean operation, I get an error. In this most recent iteration, I've got a 10mm thick shell, and when I try to get the intersection with a block I've extruded underneath it, I get an error. Here's the link
Why? How should I make it differently?
  • naregjannaregjan Member Posts: 6 EDU
    (also I realize this should probably be in "using Onshape," but I don't think I can move an already existent post)
    Now posted here in a more appropriate venue, sorry 😅
    @naregjan - Hello. In your screen shot Extrude1 is shown to be failing, but in the model it is succeeding! :)
    In fact, the entire Feature Tree has no errors! (well done) :)
    Philip Thomas - Onshape
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,059 ✭✭✭✭✭
    And herein lies the lesson of linking forum request posts to a revision of the doc not the live main workspace...
    [Patronising mode/off]
