Struggling with Named positions/views in drawings
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 265 ✭✭✭
edited July 2019 in Community Support
I’m struggling with Named positions in drawings:
  1. I created 2 named positions in an assembly while the drawing of that assy already exist:
  • I updated the drawing (Ctrl-q).
  • I tried to change the view orientation of a view (=front) to a view orientation of a named position. I did not succeed!
    Is that because the orientation of a view is not changeable afterwards in the view properties dialog or is there another method?
  • Named position/view in a new drawing of the existing assy ‘1’:
    • I created a new drawing of the assy with the 2 named positions.
    • Now the named positions did not appear in the view name list of the Insert view dialog.
  • Named positions in a new drawing of a new assy:
    • As a test I created  2 named positions in an assembly which has no drawings.
    • When creating a drawing of that assy then also the named positions did not appear in the View name list of the Insert view dialog.
     Please can you help me?
    Henk de Vlaam
    • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 265 ✭✭✭
      @NeilCooke,
       Thank you. It's clear now.
      I thought that it was possible to create views with assy components in a predefined position - a named position. Although I need that, I think that is not possible yet, isn't it? It’s only the orientation of the assy, right?
      Henk de Vlaam
      @NeilCooke and @john_mcclary,
      Thank you for your additional info.
      After the first info of Neil some of them already past my mind.
      Henk de Vlaam
    • rune_thorsen229rune_thorsen229 Member Posts: 182 EDU
      edited March 2020
      NeilCookejohn_mcclary I think these explanations are good and would like them to be clarified on the help page.
      However I try to figure out if it is possible to syncronize these two 'view' & 'position' to have to assemblies. They should be linked so if you change mates/parts etc in one then it would reflect on the other. I've explained further here:
      https://forum.onshape.com/discussion/13115/design-flow-for-3d-printing
    • Aly_KhalifaAly_Khalifa Member Posts: 3 PRO
      in ASSEMBLIES, I found you could save a Position, and then simply create and save an Exploded View without moving the components. Then when in the DRAWING, refresh and specify the "explode/position"
    • GWS50GWS50 Member Posts: 491 PRO
      I usually create a duplicate assembly to show different positions but your idea is much simpler...thank you.
