Default Material Properties
thiagomarinho84
                    Member Posts: 5 ✭
                    During early stage designs i typically have several parts made with different materials and just want to get a quick mass estimate, evaluate equilibrium and rough passes. Whenever I try to calculate mass properties for a part that has no material the tool yields no results, not even in volume.
For my purposes it would be great to have a default material property (configurable or fixed to a specific mass of 1 ton/m³). This way i could set my major components to the correct material, leave the eletronics alone and calculate a quick ratio for specific components with known materials. This would make the iterative design process way faster eliminating the need to use the slow onshape UI to define material for every single part that are just block representations of the final products still to be detailed.
4
Thomas
You can set the material of multiple parts at once.
You can choose your material by typing the name and it will narrow the list down quickly.
Or You can create a custom feature and have it sit at the bottom of the tree that grabs all parts in the studio and sets their material to a default.
Any material you set manually in the part studio will override the custom feature.
