Boolean Operation - 2 Parts w/Substrat
robert_melascaglia
Member Posts: 42 EDU
in General
Hello All
I cannot seem to remove what is left from the Boolean operation of a tube joining another tube at 90 degrees, see the sketch.
I want to remove whats left in the notched-hole; but when I delete, the tube goes along with it. So gents, what's up?
Robert,
Robert,
It is an extra step(s) to hunt-and-peck for the 2-4 similar part names to delete them. However, your suggestion produces the desired results, thanks.
Problem Solved.
If you post a link to your document (instructions here: https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first ) we can take a more holistic look at the document and see if the issue can be fixed be editing an earlier feature, rather than just tacking more features on the end of the parts list.
