Pattern tool/ extrusion question
So just made a cut extrusion into my part and I'd rather not redraw everything again on the adjacent sides of the part. Is there a way that I could use the pattern tool as a rotary pattern in this situation? Or is there just a more efficient way to make the same exact cut extrusion on another piece of the part? I've attached pictures of the part.
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
Circular pattern is the tool for this. You would need to use face pattern and select the inner faces of your cut. You will also need a sketch line in the middle of rotation.
Please let me know if you need screenshots.
ps. You could also draw just one segment of your model with cutout and use circular pattern to create the rest.//rami5 -
Here is link for public document:
https://cad.onshape.com/documents/d29ff8e74a0f49809e533f48/w/48fedb2064cc4f30a27ee6e8/e/1563fb5553e4459b85aeb10e
Check out tab 'Circular pattern' - I will add another one with your model//rami5 -
Document is now updated with tab 'draft practise (dan)'
Here's screenshot://rami5 -
I'm not sure if you already noticed but you need to check 'Face pattern' when patterning cutouts. It's not the best since it will break if you change the original cut so that there is more faces.
I (among others) have already suggested feature pattern, you can put feedback (from ?-menu) on that if you would like it too.//rami5
Yes, could you send screen shots, please?
Here's screenshot:
Onshape treats us as adults, handing us the keys to the 'good stuff' in the form of primitive boolean operations, available from within the feature-generating tools.
With this power, comes responsibility
Most modern MCAD does not trust the user in this way, presumably because they do not want to be tainted by the backlash from misuse, or because they think the public is incapable of the higher level of abstract thinking which can be required in complex instances:
However, my feeling is that (particularly when modelling tricky stuff) it always pays to use the simplest tools for the job: not the tools which make things simple for the user, but the tools which make it simple for the software.
