Automation
adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 302 PRO
I know is still pretty early in the game, but without the existence of Configurations (like in SW) I have a hard time visualizing how I could Automate finalized Products. Configuration and Equations were the key, are there any current counterparts of those concepts in Onshape?
CAD Engineering Manager
    I have understood that we are allowed to expect these functions to Onshape.
    The flexibility to do this will be put in in some way or some form, but right now don't have this functionality available.  Our system and our platform allows for multiple possibilities for accomplishing this.
    Jake Ramsley
  • adrian_vlzkzadrian_vlzkz Member, pcbaevp Posts: 302 PRO
    Awesome, will be patiently waiting to try that functionality.
    Configurations of some form will be needed especially in assemblies. At the moment for some parts you can do a inplace copies in the part studio and then change the copied part to the new "configuration/version) with direct edits. Depending on design intent you can still do changes up the tree the blow thought to parts after the copy. Works well when you then drop these parts into an assembly with the all parts independently listed.
    You can also do quite complex equations in the dimension dialogue, not a design table, but very useful. Biggest thing I find I lack is the ability to link dimensions. Hopefully we will see the linking of dimension soon ie D2=D1+10
    Its hard to patiently wait
  • 3dexter3dexter Member Posts: 89 ✭✭✭
    +1
    ....  Hopefully we will see the linking of dimension soon ie D2=D1+10
    I think it's OK to wait impatiently!
    But I suppose Zen techniques are another possibility ...
    In a restricted subset of instances, it seems feasible to use versioning ("Manage versions" icon) as a crude substitute for configurations.
    I don't think it helps where multiple versions are to cohabit within a single assembly, though... unless you round-trip them to another document, in which case you would lose the ability to edit parametrically (no feature list).
    I' ve tried using version and branching for crude configurations, all got too hard. I don't think I'd go down that track again just have to wait for proper solution.
    Recently I've been doing various conceptual redesigns to released products done in SW and so wish I had versioning and branching. It really going to make life a lot easier, no more pack and go and editing parts by accident end up with double ups, etc,etc.
