Fillets, Chamfers, & whatever else
Ed_McGuireEd_McGuire OS Professional Posts: 24 PRO
When Designing complex multiple parts in one studio, and start adding fillets, chamfers, & whatever else this can be applied to.   After a first Version is designed and all the fillets, chamfers are in.  When you come up with a change,and start Version 2.  As changes are made, fillets, chamfers go "missing" because the part changed.  Take fillets for example.  When you re-open a "fillet", it does show missing edges in Red.  Yet, it would be nice if the "icon" turned Red.  That way if there are 5, 10, or more fillet "branches".  It is quick and easy to see which ones need attention.
It would also be nice to "drag down" and expand, make bigger, the fillets, chamfers windows/boxes and whatever else.
    Meg Ryan levels of "Yes" to this please.
    lougallolougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002
    @Ed_McGuire This is about adjusting and highlighting, both of which are in for voting already.
    @lougallo Awesome!
    tim_hess427tim_hess427 Member Posts: 648 ✭✭✭✭
    @lougallo - I tried a few searches on the forum, but don't see a feature request for adjusting window/box size. This is something I'd like to vote on (unless I have already and forgot about it). Do you have a link to that post?
    Thanks!
