Barrel Cam, Tangent Mate, Seam from Wrap
t_cary
Member Posts: 9 ✭✭
https://cad.onshape.com/documents/44def3197a3061817f6e8b0b/w/49ae5ba3afddb58e9e4759e6/e/a6953ccdf7cfced00a8a9a44
I can't Wrap a Profile that is PI*Diameter long. It errors. So I have to shorten it a bit. This causes a seam that breaks the Tangent Mate on rotation.
Is there any way to work around this?
I had to make the Tangent Mate to an edge. For some reason it won't let me use the part surface. But that I can build around...
Thanks.
Thanks.
NeilCooke
Moderator, Onshape Employees Posts: 5,990
I straightened out your sketch to ensure both ends were tangent to each other, then used Replace Face to close the gap, then used the edge (not the face) for the tangent mate.
https://cad.onshape.com/documents/74a5771d3ceb58266988210d/w/fc4427a19f20f056ab1ba37f/e/4eb60ffec267ff8c6253f6e1
Senior Director, Technical Services, EMEA7 -
t_cary
Member Posts: 9 ✭✭
Thank You. I had tired making them tangent, but I would never have figured the second step.0
If you put an extra seam on your profile sketch, it should wrap the way you want, and produce a result with no seam, and no need to shorten:
https://cad.onshape.com/documents/eef29680e01fe239a122e274/w/b8e2c0f3629748a6252da7a3/e/ee457eed66a2fd43b293d9ba
